My question is relative to suspension setup. Over the last year, I've started with the critical things like alignment and tires, Then I swapped in Prokit/Agx. My setup feels good on the street (my intention- bad roads), but I was wondering if I should get aftermarket sway bars as well. I have a high distaste for body-roll. And the limited drop (and LESS STIFFNESS IN THE FRONT) of the eibachs, still allows for substantial roll. Will an extra-stiff sway, such as whiteline, make my car corner flat only to have my actual corner-grip/handling suffer? The eibachs are only stiffer in the rear spring, and even then not by much.
I've been searching through NICO, and Its generally recommended to tune with springs first, then sways. It's just that I don't think I could go much stiffer for the street, but I want less roll....
Anybody run Prokit and Whiteline sways? Thanks for any experienced insight you can give....
