Postby
IlIkEmYz »
https://forums.nicoclub.com/ilikemyz-u11744.htmlSun May 09, 2004 3:40 pm
i was going to go sr but decided it will probably be more moolaa
so right nowi have a ka24e and i want a solid turbo set up that's the best bang for the buck. i also want one that can also be switched over to the ka24de when i engine swap.
any suggesttions??
keep in mind this car is going to be a daily driver so gasefficience would be a good idea
Postby
j-z »
https://forums.nicoclub.com/j-z-u11653.htmlSun May 09, 2004 3:40 pm
whats a justy? when you go to swap to the twin cam motor youll need a different manifold. other than that everything else should work depending on what engine management you go with. a solid setup is one that is well tuned.
Postby
andrave »
https://forums.nicoclub.com/andrave-u6358.htmlSun May 09, 2004 3:40 pm
yeah your IC piping, downpipe, and manifold will probably all be different when you switch engines, along with uprated injectors/ fuel rail and possibly your fuel management...about the only thing that would remain constant would be your tubo and intercooler...
Postby
C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.htmlSun May 09, 2004 3:40 pm
Actually changin over wouldn't require a lot of changes. The only real big difference would be the location of the throttle body and the manifold. But trying to build a manifold to put the turbo in the same place would require some good planning and set-up. And I would agree with Checkered Member and swap in the new motor first.
Postby
Def »
https://forums.nicoclub.com/def-u8646.htmlSun May 09, 2004 3:40 pm
When the swapping the engine costs less than even the cheapest new turbo, and it gives you a 15hp increase, I just don't see how you could not want to do that first.
