RemixZ »
https://forums.nicoclub.com/remixz-u77781.html
Tue Mar 02, 2010 10:11 am
I wanted to get solid sway bars like on my z32, opposed to hollow sway bars...So was thinking of getting Whiteline...Are there any other brands that are cheaper than Whiteline that are solid? If not, if I got one sway bar at a time with Whiteline, which should I get 1st..fronts or rear. I'm thinking rears, cause the front is pretty beefy to begin with. Ill be using on stock suspension, but after I get both sway bars, I'm will start saving up for some Bilstein coilovers...
Also, I heard rubber compared to polyurethane is better for bushings?
Discuss
Thanks!
