180fan wrote:loosen the bolts, but only take one bolt out at a time. support the subframe with jacks and jackstands while you work.
dude, how exactly are you going to press out the old bushings like that?
yeah, I got some ponters...
1. get a air chissel2. get a acetelyne torch3. optional, but man if I ahd this it'd ahve made my job way easier(I found it in a mechnics tool chest at work after a day of work, and it madethings go sooo much easier)...a bearing/oil seal press-in kit..it looks like a little handle with a small conical top that spins on it. you use it to hit the bushings to drive it in STRAIGHT..which is very important.3. lots of patience
drop your sub frame out, remove diffy, etc. go ahead and put the SPL bushings in the freezer. you'll want to busrn or cut(sawzall works, but be carefull) the old bushings, then you get to deal with the ring around the bushing if its rusted in..use the air chissel to get those out, but be carefull of the angle and chissel head you use..otherwise you'll damage the sub frame. just chissel the old ones out, then sand(lightly) any rust/bumps/etc from the bushing seats(the inside of the hole) annd the top edges..
I also put a drop of silicone around the bushings to help them slide in a bit.
supporting the sub-frame, drive in the new bushings(which will be frozen, TAkE OUT ONLY A PAIR AT A TIME so the othe ones dont thaw) with the pressing tool, or block of wood and hammer...make sure you get dead-on(center) hts and keep the bushings centered.
have fun. it took me 3 days of on-and-off work.*but then agian, I had a spare sub-frame with bushings that were rusted in)-chet
