kpodj61240 »
https://forums.nicoclub.com/kpodj61240-u70147.html
Fri Dec 25, 2009 1:06 pm
Ok so hears the deal I bought a set of solid sub frame bushings but all I hear is that wheel hop is eliminated (which is my problem) but ride comfort is decreased dramatically. Now they say the vibration is much worse in an s13 compared to the s14 because the s14 has a "floating sub frame". So I want to put them in but then I want it to be comfortable. I want the best of both worlds, but I know you can't have your cake and eat it......but maybe I can .
I saw these and was like daaammmmmiiittttt. I should have waited and got these because I bet that "rubber looking washer" on top helps to reduce that vibration a lot.
My question is, can I add a rubber or Poly washer on top of the solid bushing before installing them so it will reduce the vibration everyone complains about. Or will that not work because I am technically adding height to the bushing. I know its not much but could that little difference "screw" something up in a way or would I have to shave the medal down to make up for the added washer. I mean If you think about it poly bushings and oem rubber bushings flex, squeeze, expand etc. so that changes the height anyway.Thank you
I just want to verify if this will work in a beneficial way. Merry Christmas
