solid pivots
driftfan420
I was looking at going with the Tomei solid pivots for rebuilding my SR20 head. I was curious to know if there would be an adverse reaction if i didn't use solid type cams. I have the Toda 264 w/ 10.5 lift ( http://phase2motorsports.store....html ; http://phase2motorsports.store....html ), and not sure if they are the solid type. I know the lift profile isn't high but still having the piece of mine knowing i can run it to 9K would be nice and keep in line with my power potential.
Also, just testing the water. just curious about what i should see this car for if i put it on the selling block. Exterior's clear coating is chipping and right rear quarter panel has been scrapped when putting into garage. Engine isn't finished yet but will be completed in 2 weeks so its a fresh rebuild . Rear interior has been gutted and will be replaced with show quality fiberglass enclosure to fit sound system. Hopes are the car will run 400WHP.
Drivetrain:
Nismo Engine/transmission mountsACT Heavy Duty 6Puck 463 ft/lbs torque : S13/14 SR20Nismo steel braided Clutch lineVLSDNismo Slave Cylinder and pivotFidanza lightweight fly wheel/ Fidanza Friction plateOne piece steel drive shaft
Suspension:
Tein super street CoiloverSuspension technique sway barTanabe Sustec Strut Bar front/rearNismo Power Brace S13
Braking Power:
Brembo slotted brake rotors ( Stock 240sx 4 bolt pattern)Hawk break pads1 Agency Power Stainless Steel Brake Line Kit Stock Front1 Agency Power Stainless Steel Brake Line Kit Stock Rear
Engine Upgrade:
Top end:
TODA SR20DE(T) Intake camshaft 264/10.5mm TODA SR20DE(T) Exhaust camshaft 264/10.5mm 1 Ferrea Dual Valve Spring Kit for Nissan SR20DET Ferrea Valve seats Ferrea Titanium valve retainers 1 Port Flow Manganese-Bronze Vallve Guide Set 1 Brian Crower Exhaust +.5 Valves for SR20DET 1 Brian Crower Intake +.5 Valves for SR20DET 1 ER Spec Stainless Rocker Arm Stoppers Cometic 1.1 87mm metal head gasket, Copper Exhaust gasket, Metal Turbo Gasket, ARP Head studs
Bottom End:
-CP Pistons 86.5mm 9:0:1 compression-Eagle Connecting Rods with ARP hardware-ACL Bearings.-Main Bearings-Crank Bearings-Thrust Washers
Fuel System:Walbro 255 Fuel pumps Tomei 740cc InjectorsZ32 Fuel Filter Nissan SR20DET NGK Iridium Spark Plug Set for Nissan SR20DET (Heat 9)Sard Feul Pressure Regulator hose type fitting
Power Upgrade:Greddy gt2871R turbo Taka S13 SR Bottom mount Turbo Lines:w/Taka Ball Bearing Oil RestrictorGodspeed intercooler w/ custom intercooler pipingHKS hotpipe w/ssqv BOVGreddy intake plenium (polished) Snow Performance Stage 1 Methanol KitTomei exhaust manifoldTomei exhaust elbowMagnaflow highflow cat.Catback system ( type Unknown)
Engine Cosmetics:
Flex-A-Lite model 345 Dual fans Nismo Engine/transmission mountsPower Super V-Belt S13SR-Belt-Set/Main,P/S,A/CGreddy SR20DET Oil Pan Megan Racing S13 SR20DET Light Weight Pully SetSamco hoses ( radiator, couplers, etc.)Greddy Oil Filter Relocation Kit for Nissan S13 SR20DET MA powersteering custom line (powersteering line)Color BlueMegan Racing 1 3/8 water temp adapter Circuit sports oil catch canCircuit sports polished coolant tankKoyo RadiatorNISMO SR20DET Grounding kit(4 Gauge)
Interior Upgrade: Fiberglass Dash with custom molded gauge pods2 Megan racing Seat Belt Harness2 Megan racing reclineable seats2 megan racing seat bracketsReal Carbon Fiber trim kitCusco 4 Point Roll Cage Nissan 240SX S13 91-93 Harness barCarbon Fiber door panelsMomo foot pedalsMomo gear shifterMomo steering wheelquick release adapterSteering Hub
Gauges/Controllers:
Apexi Power AFC-II Greddy Turbo TimerAEM Uego (Wideband)Saga Technik Gauges (fuel pres, oil pres, oil temp, water temp, Boost )Audio:
4 8” Rockford fosgate sub1 12” Rockford Fosgate Sub2 6 1/2 Kicker component door speakers2 Kicker Tweeters1 Rockford fosgate amp1 Rockford fosgate amp2 Rockford Fosgate capacitors Custom fiberglass sub enclosure/ amp rackKenwood deck w/ USB connection
