Ender_Zero wrote:if this is a track car that would be ok, but i think the vibration is a little more than you think itll be if its your daily driver...
side effects: headaches if sitting idle at a stop light, cd players not working so well, and a near permanent hard on for you and any male passengers. if you like cleaning up wet spots put a chick in the car and let it idle for a bit.
This is what Im doing, except Im going to use my own transmission mount.deviousKA wrote:Get a decent set of used mounts, clean them well and remove any residue, and then fill them with 3M windo weld. Use some wd40 sprayed on your finger to help push the windo weld in the grooves and then build the outside of the mount up with some more. Smooth it all out nice and let sit for a few days, you will have very solid mounts that will last a couple years.
