solid lifter head reshim nightmare!!! please help
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
on my quest to do a write up on a cheap way to shim my solid lifter setup for cheap i have ran into a problem. i have tomei built head, cams,springs,retainers,lifters,ras. i need rocker arm guides that are larger than 3.00 mm and cant find a solution. tomei and nissan only make the guides up to 3.00 and 6 out of 8 of the guides need larger than that. the shims, they make all the sizes i need......just not the guides. please help.
compactfean
daily
So I searched all day yesterday with no luck.also called frsport to see if tomei makes bigger guides because on tomei's website it says they have other sizes but come to find out they don't make anything bigger than 3mm. If you guys have any ideas let me know. Im going to the machine Shop today .....wish me luck.
