Solenoid on the AAC valve body???
Rennfab
Hi Folks. My first post here and sorry it has to be a stupid question.
I've got a 280z here with a series 1 Rb25det in it that has a mess of an electrical system. I've sorted 95% of it out but have two questions I was hoping I could get an answer for
1) the car was completely missing the MAF and the harness pigtail. I have sourced a brand new J60 MAf for the car but still need the pigtail. Can someone tell me if a Z32 pigtail will connect to this MAF properly? The MAF looks awefully similar to the one that was in my EG33 powered subaru WRX and the Z32 connector does as well so I'm assuming I can use it on the J60 but just want a 100% yes or no before I buy one.
2) On the AAC valve body on the back of the plenum is a small hex shaped solenoid with a purple, two-wire electrical connector going to it. The wires goign to this solenoid were cut back in the harness, but I cannot find where they terminate to nor can I find what this solenoid is on any of the wiring diagrams I have. What exactly does this thing do or what is it called? I have one diagram that shows something called a Throttle Valve Switch, but I have no idea what that may be(it's not the TPS I know that)
Here is a picture of the solenoid and the associated wiring that came out of the harness on this car:
I've worked on and am pretty familiar with the RB26dett from the GTR's but this is my first RB25det powered car I've had to dive into repairing electrical issues.
Thanks!!
Carl H
the solenoid is the FCID solenoid...its used for ac high idle on the stock efi, not needed for your swap.
regarding the pigtail, it might fit but do not assume the pins are in the correct location.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I just rewired mu harness and traced this, hold one
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Hmm I think I found it, there should only be one wire on the W-1 connector that is yellow only, black is a ground
Rennfab
Thanks for the response guys. I'll leave it disconnected for the time being as the car does not have the AC equipped at all. I'll take a chance that the pigtail fits the MAF plug and work out the wiring to the J60 when i get it in hand.
Thanks!
