Looking for some insight on swapping out my transmission solenoids. I've been tackling this issue for a few days and a few trial and error attempts not sure what is happening so I'm hoping somebody can figure something out that I can't.
First question is on the spring positioning. According to this picture on the valve body, the front of the engine the first slot is left open with no spring it. However, on the service manuals and a tear down video there is, and all the springs are shifted towards the front of the engine leaving the rear one empty. Leaving the rear one empty, this is correct yes?
Second question is on the manual valve positioning, there's a nub on the manual plate, they slot into each other correct? It should look like this if I have it properly.
Third question is I bought this solenoid kit, https://www.rockauto.com/en/moreinfo.ph ... 1960&jsn=9
I believe if it the right one, but I'm not entirely sure, I couldn't find the exact part number off of the OEM one. There is also this one, which I believe might be correct.
https://www.rockauto.com/en/moreinfo.ph ... &jsn=12172
Thanks for any insight. Appreciate it.
