Soldering walbro fuel pump question
tErbo b00st
I am doing a swap :D, so I am installing a 255 walbro pump and you need to solder in the power wires. What should i use to cover them up as these are going to be in the gas tank and i dont necessarily want a spark in my gas tank. What did everyone use?
robbbby
I didn't solder, I used the supplied butt splices to connect the wires.
Nismo_Freak
Car: 89 Nissan 240SX
You're supposed to use butt connectors.
Datsun
I soldered mine. No problems.
NoStickers
Car: 1991 240sx w/ sr (RIP)
1989 240sx w/ ka
1996 240sx donor car (coming soon)
i soldered mine too
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
FYI, gasoline does not conduct electricity. I used the crimp connectors that came with my walbro and dropped it back in the tank.
tErbo b00st
For you guys that soldered...did u cover it up w/ anything or do u just have the bare wire/solder sitting in the tank?
180fan
Car: 89 fastback
I tried soldering mine and the fuel pump fuse kept blowing. Put the crimps on and no problems. Dunno what's up with that.
slw240sx
Car: 1990 Ca18det 240sx Hatch
you suck at soldering !
NoStickers
1989 240sx w/ ka
it was soldered on the stock pump and was exposed so i did it the same way on the new one
180fan
Car: 89 fastback
slw240sx wrote:you suck at soldering !
uh yeah thanks dude.
primeral
Car: S14, S13, Xterra
180fan wrote:I tried soldering mine and the fuel pump fuse kept blowing. Put the crimps on and no problems. Dunno what's up with that.
My theory, when in the tank, the gasoline dissolved the adhesive on your electrical tape, causing it to short. Very dangerous, considering the sparks are happening inside your gas tank.
NismoFreak knows I solder everything and I religiously use shrink tubing. I use transparent shrink tubing when I have a choice because it allows me to inspect the joint without unwrapping anything. It's the only way to fly at $1.80 per 4ft stick
Datsun
No, I did not cover the connections after soldering. Left them bare ***. There are no sparks "flying around" in the gas tank.
s13sr20chris
heat shrink is good.
180fan
Car: 89 fastback
funny thing is that I used heat shrink tubing too. I always solder my connections but was told that I should try crimping when the soldering didn't work. It's not like I don't know how to solder but dunno just found it strange that it'd work one way and not the other for my case.
s13sr20chris
whatever works for you. crimping is not really bad. its just that some of us are anal about electrical connections.
