Yeah thats my main reason for not relocating the batteryEZcheese15 wrote:Thanks for the correction!
^ this is very true. when you have to deliver an unaltered signal, always solder the connection points.EZcheese15 wrote:A good solder is a much more secure connection than a crimp. And when you are dealing with engine controls, fuel maps, etc, you don't want a bad signal.... A bad connection on an ECU wire could cause you to blow a motor, depending on what wire it is.
Remember that most of us don't live or drive in outer space. Just to be clear, you're recommending the use of pure silver connectors for a crimp application? Please satisfy my curiosity and direct me to a vendor who sells pure silver crimp connector leads.PoorManQ45 wrote:I do know what I'm talking about when it comes to metallurgy.
Silver has a rating of "105 IACS".
This is, of course, more conductive than annealed copper, which as you probably know has a rating of "100 IACS"
I'm sorry, I completely forgot about the most important factor. Are the metals compatible.Q45tech wrote:It is not the absolute sign but the difference between metal that counts.
Wow. That is some serious stuff.Q45tech wrote:I have tremendous experiences from another life soldering large hundreds of 1 foot wide 200 foot long copper straps and massive copper ground screens covering quarter acres together with real silver solder and 60/40 rosin core solders where the skin effect [where the signals travel on the outer electrons of the material] is critical in 50,000 watt AM broadcast stations in the 60's.
Please stop insulting me. If anything, critize everything that I say.DAEDALUS wrote:Remember that most of us don't live or drive in outer space.
Actually, I was thinking more on the lines of pure silver wire. Connected my a pure silver solder. There probably is a company that sells pure silver crimp connectors. Q45Tech could probably direct you to one of them.DAEDALUS wrote:Just to be clear, you're recommending the use of pure silver connectors for a crimp application? Please satisfy my curiosity and direct me to a vendor who sells pure silver crimp connector leads.
Guess it doesn't matter after all... just suffered an oil pump failure and will be rebuilding the engine. I will just move to a custom wiring harness and a Motec M4 engine management system.Q45tech wrote:I doubt it will improve anything as the engines are tuned over rich in acceleration.........more [higher] MAF voltage will just make it worse.......even 0.001 volt above the design numbers [1.2> 4.4 volts] will make it richer.
Same with TPS, etc.
All thermistors [coolant and air temp] are negative coefficient [ causing a higher temp reading with less resistance].
Even O2 are not sensitive to exact voltage as a mispoint of 0.4-0.6 volts is ok as long as the less than vs greater than midpoint switching occurs......anything from 0.65-0.99 volts or 0.1-0.35 volts is ok.
The engineers designed the signals [as received by ecu] to be tolerant of a little corrosion which might decrease the voltages by 10-20%.
Critical signals like crank position are backed up for safety and regenerated to square up the pulses so that the ecu can maintain timing to beyond 7,300 rpm.
