Fla240sx »
https://forums.nicoclub.com/fla240sx-u71754.html
Thu Aug 23, 2007 3:07 pm
ok theres been a lot of talk about vacuum lines lately... and I myself was very interested.... and there are lots of vacuum lines hiddien around, lots of T's, and lots of confusion.........
I will make pics tomorrow when I have light!!!!
so I really sat down and took some time to figure out everything.... and came up with an extremely simple solution... Now I'm running the bare minimums... and thats all this how-to applies to.......
ok so its been said that all thats needed on the car is the Brake booster and the Fuel Pressure Regulator.......... I've taken the vacuum off of everything else and my car runs the same.... I cannot say yours will, I claim no responsibility for your work or your parts....
From my understanding, their are THREE hard metal ports that come off the intake manifold that provide vacuum... besides the big one for the Brake booster..... I took two of them and looped them together.... The ones by the throttle body.... I cut off a piece from one of the lines going to the Charcoal canister for this purpose... then just stuck the ends onto the two parts........ bam two vacuum ports easily plugged
Now the 3rd one..... and this is an easy one... just take another properly sized vacuum line, again I reused an old piece....... and routed it directly to the FPR
so in conclusion, I now only have 3 vacuum lines on the car, one that loops together two ports... one that goes to the FPR, and one big one on the firewall going to the Brake booster.......
you MUST also make a plug for the intake tubing to plug the vacuum line, mine is the stock plastic one... its the smaller of the two ports by the throttle body... I used a bolt pushed into it with some sealing tape that is kind of like tar around the head to seal it off completely.....
you can now go about removing anything else that runs off vacuum that you no longer need, in other words all the emission parts, and every other metal lines or rubber lines that hold vacuum that are no longer used..........
pics tomorrow, you can do this with some cutters, hell maybe even scissors, and about 5 minutes of your time........ its pretty damn simple! When you see the pictures of what I did, you will want to get rid of all those POS vacuum lines and emissions equiptment with a big smile on your face....
plus my header will be here next week hopefully and I can also gut the entire EGR and STUPID AIV system... which really cleans up the car a lot
