lucky03602 »
https://forums.nicoclub.com/lucky03602-u20182.html
Sun Nov 05, 2006 4:51 am
also as far as using stock internals with a turbo set up, what wasnt said and is actually common sense is your engine would be fine as long as you dont put alot of boost to it, you say u want 180hp so im assuming your gonna run 5-7psi of boost which is fine on stock internals.
what kind of a setup/parts you think your gonna be using for your car btw??
