syka24et »
https://forums.nicoclub.com/syka24et-u3967.html
Sat Mar 15, 2003 1:36 am
I have been searching for a turbo cam for my SOHC ka project and have cam across a few possiblities. I contacted colt cams via e-mail and got a reply in a day. The e-mail said the following:We offer two very popular grinds for the Nissan 240 SX ( KA24) 12 ValveSOHC.1st stage: INT: 260° .424 Lift ($200.00 Canadian / $150.00 US) EX: 268° .441 LiftThis is a great wake up grind and gives a stronger mid range withoutsacrificing bottom end torque. The power band is approximately 1500 - 5500r.p.m.2nd stage: INT: 268° .441 Lift ($225.00 Canadian / $168.75 US) EX: 272° .442 LiftBest all around cam profile giving a slight idle sound and very strong midto top end power increase. The power band is approximately 2200 - 6500r.p.m.NOTE: No modifications are required for stage 1Stage 2 requires approximately .025" - .030" milled off the top of thecamshaft bearingcaps, where the rocker shafts secure. This can be done at almost any machine shop.
I am considering stage 2 seriously but I would like to rev the car to about 7400, ( the engine would be fully built) they say power is up to 6500. Will a profile more radical than this, be unstreetable. I also contacted racetep about the specs on their regrind but got some bs automated response. Any way my hp goal will be about 400 on high boost, so in your opinion will the stage 2 be adaquate for this. Also if anybody knows of any other companys that do good work or of a profile that might better fit my application I would apprecite it alot. Thanks in advance. P.S The car will be street driven but I'm not scared of a little ruff idle.
