sohc transmission swap.. need some help on this one.
mrfarenhight15
Car: 89 240sx
where can i find a transmission for this crappy motor, and is it a hard swap?
neverlift
is it the water or what search before posting from now on a dohc transmission is the same except obdII they have some sensor or something.....
unbolt old ,install new
mrfarenhight15
Car: 89 240sx
well, i did search and didnt find what i asked worded the way i put it, so i asked mine. thanks though
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
The hardest part is getting it back in. E and DE trannies up to 96 (pre obdII) are the exact same.
WWJD
SOHC are troopers
roadXvillians
Car: 1990 Nissan 240SX
so can you use a transmission off a sohc and put it on ka dohc? will that work?
LingeringSuicide
Car: 1990 240SX hatchback 1993 240sx Vert
YES!
bone_stock_240
Car: 1995 Infiniti Q45
wa-chiss wrote:The hardest part is getting it back in. E and DE trannies up to 96 (pre obdII) are the exact same.
+1. Getting it out takes a little time and some elbow grease. Putting it back in takes more time, more elbow grease, and lots of finesse.
The only difference with the OBDII transmission is it has a crank angle sensor in a little hole at the top of the bellhousing. You could leave it in, or pull it out and plug up the hole.
coupe240sxguy
Car: '89 240sx/ '01 mazda 626
Hey noobs, welcome to the site! Try to search as much as needed. Not many people search tho, that is why the search button is at the top of the menu blinking red. If you need help with anything click on the link below. It is very helpful to many, or you can just ask me. I will help as best as possible. gl
