sohc to sr20det wiring help
theonlyhonda
Car: 98 integra and 90 240sx
i just finshed a sr swap into my 90 240sx and when i put the positive white terminal wire on the battery it sparks, here is a pick of the wire its the thickest one to the left
heres a coulpe of picks of the ka to sr harness
if anybody has any input on what i did wrong on the wiring please lmk, i checked the wiring an i dont see wires that i missed
dash plug
theonlyhonda
21 views? an noboday has an idea?
k00laid83
look man it looks like you never have done wiring and it seems like you really haven't researched very much. but from the looks of things and the use of those connectors your just going to run into more problems. I think your best bet is to send out your wiring and have it done to make things less of a headache for you.
theonlyhonda
k00laid83 wrote:look man it looks like you never have done wiring and it seems like you really haven't researched very much. but from the looks of things and the use of those connectors your just going to run into more problems. I think your best bet is to send out your wiring and have it done to make things less of a headache for you.
i just followed the guide by frsport, i used those connectors just to see if the car would start, i soldered all the connections i just took it apart to see if there is anything i missed but, i know it look like a mess.
k00laid83
dang man i dont even know where to start i wish i could help you out bro...i just think you should keep going over your wiring.
Wiring Specialties
Vendor
You need to re-post the pictures.
theonlyhonda
i fixed the problem, i was reading the fsm an found out it was the lower harness, the lead alternator wire was grounding out, so i redid the harness an put it back on together the correct way, thanks again guys. its always the little things that screw me up lol
