kamikazi »
https://forums.nicoclub.com/kamikazi-u35227.html
Sat Mar 31, 2007 5:30 am
yes, in order to have a correct tach you will have to change the cluster. in my sr coupe i have the sr tach that shows 9k and i would recomend it. you should be able to easily find a company that will take your tach out and put the sr tach in.
edit: you will have to pull you cluster and send it off.
