It is a complete harness, Only now I've found out the douche bag who sent it to me from texas lied that it was for a 5 speed transmission. I got the VIN of the car it came out of is there anyway I can see if it was an auto or a 5 speed. cuz theres 4 plugs on my transmission and only one on this harness.biggie wrote:For Prob 2:
You should be running complete DOHC engine harness, only splicing in the dash connector from the SOHC one to connect inside to the dash.
Alright, is there a guide on how to splice the wires for the dash harness from sohc to dohc? I didnt see it in the tech pagesbiggie wrote:You should be able to decode the VIN here:
http://garage.projectraine.com/content_ ... mid01.html
An AT harness can still work though.
A google search for "s13 sohc dohc dash plug" should find it.hoosier240sx wrote:Alright, is there a guide on how to splice the wires for the dash harness from sohc to dohc? I didnt see it in the tech pagesbiggie wrote:You should be able to decode the VIN here:
I heard recently a guy can buy a adapter kit for the tach which costs $25. seeing as how there is no 240sxs around here for me to get a tach out of this is my best option.moso wrote:you need the brake pedal ( unless you cut your which i really dont recommend ) the transmission saddle, clutch line. if your swapping your auto 24DE to a 5spd than you will want a 24DE 5spd TPS ( my auto tps gave me an issue i cant remember)
wtf do you read at all before you post???hoosier240sx wrote:no its always been a manual i aint swapping trannies.
