90fastback »
https://forums.nicoclub.com/90fastback-u11800.html
Wed Dec 03, 2003 11:44 am
Hey .. I just wrapped up my E to DE swap, took me about a day and a half.... the only thing to worry about really is the power steering needs to be switched to the driver's side to accomodate that the powersteering pump on the KA24DE is on the other side than the 90 stock KA24E... All you have to do is unclip the hardlines and the main bracket and bend them 90 degrees to the other side... also yea you need the 92 harness and ECU. And the dash harness from your 89-90 will not match the 92 engine harness. you need to cut and wire on a plug from a 91+ dash harness, you need to match 5 wires, 6 if you have AC, black, yellow with red stripe, blue with black stripe, orange, and yellow with green stripe i believe, also the tach signal from a 89-90 cluster differes from 91+ so you need to get a new cluster to make your tach work.... Hope this helps !!
