fiveoh »
https://forums.nicoclub.com/fiveoh-u25987.html
Mon Mar 06, 2006 7:44 pm
Which wiring harness(s) will I need from the DOHC donor car? I have what I would assume was the upper harness, that plugs into the ecu/injectors/sensors on the motor, but the plug that comes off the ECU that I assume goes to the gauge cluster doesn't match my twin cam harness? Do I have to pull the dashes out and get the DOHC dash harness?
