Sohc to dohc swap help
sdalton001
Car: 89 240sx hatch
I'm doin a sohc to dohc swap. here's what i got. i have a sohc manual transmission 89 hatch and a dohc automatic 92 coupe. will the sohc manual transmission bolt up to the dohc auto engine? and can i use the sohc or dohc ecu i have or do i need to get a dohc manual transmission ecu? thanks in advance
dnissan240sx
Car: 90 /91 nissan 240 sx se
yes it will i did the same thing but you will need the comp. for the dohc and change all the harnes frm front to back .if you need any help just ask
nzmoman
Car: 240sx 2 of em' and always lookin for more
You will also have to get your Power steering sorted out. you will be switching the pump side. so pull the lines off of the DOHC car or order them. im sure someone in classifieds has the set for sale if you need. Or you can be old school and not run PS
