deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Sun Oct 31, 2004 4:20 pm
Yes it is possible, you have a few options. First of all i would say it is in your best interest to find and use a 98+frontier cylinder head. This, like an altima head, requires much less extension of the lower sohc cover to fit the de head. This also allows you to use either a 240sx de intake or truck de intake (basically identical to sohc truck intake). A truck dohc ka block is pretty much a truck sohc block, only minor difference being where the front cover of the head mounts. Im 95% sure you could even use a truck dohc lower timing chain cover on a sohc truck or 240sx block which would make everything a bolt up affair. Truck de use both sohc type oil pump and distributor.
You could always use a 240sx cylinder head, not as easy as far as fitment on front cover. Or an altima head, which requires custom intake manifold and water neck that comes out on exhaust side for radiator, but has the front cover characteristics of the truck de.
If you want to retain your oem ecu, harness, sensors, and all locations, use the truck dohc intake with throttle body mounted maf.
btw. you will want to find a frontier de exhaust manifold as well, this should bolt up to your stock y-pipe correct. Exhaust manifolds between 240sxdohc/truckdohc/altimadohc are interchangable.
