Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Jul 23, 2004 9:45 pm
The tach is simple. Get a DOHC tach. It reads a slightly lower voltage than the SOHC tach, but you can just bolt a DOHC one right in and it works. Simple.
I'm surprised they don't have any wiring diagrams if they're wiring a car. It's almost idiotic to try and hardware a motor into a car without some sort of electircal diagram.
As far as getting the oil and temp senders working, I'd have to sit down with a SOHC and DOHC wiring diagram to find out what the difference is. I have a DOHC KA wiring diagram, but I unfortunately, do not have a SOHC KA diagram, so I can't compare and guide you on that.
The motor sitting around wasn't the problem. We import motors taht were witting in japanese junk yards for years and they fire right up. When you change the oil, you pour it into the head, so it would have lubed up all the head parts before it made it's way back into the sump. I think that motor was a bit screwed before it was sold to you. In the future, I would ask for pictures of the guy taking comp readings from all the cylinders, and if possible to see a leakdown figure as well. I wouldn't rely on a motor because I saw a smog chart. Anyways, you have a new motor that has good compression, so I wouldn't worry too much about it now.
I'll see if I can't finagle a SOHC wiring chart from my friend when he gets back on Tuesday. I've been meaning to steal a diagram from him anyways to complete my FSM collection on my computer.
