SOHC to DOHC Cluster problems
bkos90
Car: 1989 240sx
I have a 89 SOHC s13 and the only cluster i have to put in is the DOHC from the 91 automatic. once everything is plugged in the cluster is dead. the light on it works when i turn the lights on but none of the gauges and the bulbs like check engine and brake work. I checked the ground wire and all but still nothing.
Anyone know what it could be?
Klits562
Car: white s13 coupe
http://www.nicoclub.com/articles.php?id=272023you have to do some rewiring on your ignition coil wires
bkos90
Car: 1989 240sx
Klits562 wrote:http://www.nicoclub.com/articles.php?id=272023you have to do some rewiring on your ignition coil wires
I know about that but the whole cluster is not working.
Klits562
If you followed the article and your gauges aren't working still then check to make sure that the gauges are getting power. If they are then your gauge is busted
