moso »
https://forums.nicoclub.com/moso-u137641.html
Sun Jan 22, 2012 10:50 am
you wont need the od switch. you wont need anything hooked up to the transmission except the reverse switch and speedo. on the lower harness you will need to hook up the two wires to the starter; you will need the plug, positive, and ground line to the alternator; and the oil pressure sensor. now that thats out of the way, have you checked the ecu for codes? have you checked your timing? did you change your fuel filter?
btw, im driving the exact same swap, no emiss, no problems! you should get this sorted shortly.
