well i changed the sensor (originally green plug, ) to the red plug found on the s13 DE, which i take is the temp sensor... which is located infront of the engine, but the coolant temp sensor???? were is it located....!?!?!?Brandon93240 wrote: Also make sure you change out the coolant temp sensor, and single wire temp sensor on the manifold so the guages and the ecu read the temp correctly.
