KA24M90 »
https://forums.nicoclub.com/ka24m90-u136881.html
Wed Jun 24, 2009 1:40 pm
Fair warning. When the tensioner guides go on this thing you dont have long (40 to 50 miles) before the chain wears a hole in the cover (right on the water passage for the pump, pretty nasty). You can get a pretty good oem timming set from SA Gear that comes with both sprockets, the chain, the tensioner, new guides that are reinforced to keep them from becoming brittle and falling apart again, and hardware for the tensioners. It cost roughly $80-$90 but if your on a budget you can find the guides cheap on ebay. I have seen them from $20-$40, just make sure they are new.
