skylinekin »
https://forums.nicoclub.com/skylinekin-u32041.html
Sun Jul 23, 2006 9:48 am
This is a 90 w/ a sohc
I had a small oil leak from my oil pump so I removed it and replaced the gasket, I set the motor at tdc cyl #1, aligned the punch mark on the shaft and the small gash on the oil pump and reinserted it into the front cover, everything went in, the distributor was still pointing at tdc cyl #1. Now it wont start, it just cranks over, and when I turn the key off, it kinda makes a poof noise. I put it at 15dbtc and checked the timing on cyl #1, it was dead on. What am i forgetting to do? This is driving me crazy, any help would be great, I can get pics or whatever you guys need. Thanks
