deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Wed Apr 07, 2004 8:08 am
Yes exactly like demcj said, looking down from the top can be very decieving as far as guide condition. Many i have done have looked ok until i pulled the cover. Only way to roughly get an idea of your chain slack, without pulling the front cover, is to look down from the top at the chain tensioner. You should be able to see the small tensioner cylinder pushing out on the left-side chain guide (left if your looking at it from the front of the car). That cylinder should not be pushing out 1/2" or more, 1/4" is about normal for a good used chain, and with a new chain it should be about 1/8". This is not a definate guide to follow, but i have done a lot of customer timing chain/guide replacements, and this is my rule of thumb. Make sure that you roll the engine over a tad bit by hand with the crank pulley, to make sure the camshaft hasnt rolled back when the engine was shut off.
You might, or might not be able to tell if you have the updated metal-backed right side guide (right side if your looking from front of car). The updated guide still has a plastic peice that covers most of it up. If you grab a flashlight and look, you should be able to see the bolts that attach that guide. The factory plastic guide uses longer bolts with large shanks, the metal back guide uses standard allen-head bolts with lock washers.
You can also look the chain itself and see if it is oem-style or aftermarket replaced. Oem the ka24e uses a high quality 06E chain that is much more heavy duty, than the 06B common replacement chain. Some of the links of the chain will be labeled 06B or 06E. Imho, the 06B chains are junk, and many that you get in timing kits even have split rollers! This may be of little importance, but i thought i would add.
Good luck, and if you do end up pulling the front cover, take your time, especially during reinstallation.
