milkmanwd21 »
https://forums.nicoclub.com/milkmanwd21-u99445.html
Sat Aug 29, 2009 1:00 pm
ok so my 240 with the sohc (little sh*t). so when i start my car in the morning and step on the gas and hold it at 1500rpms it will stutter then drop to about 1000rpms and then go up and keep doing this till the motor is warm(needle in middle of dash gauge) it is impossible to drive it like this and its very rough on the old motor so then ill turn it off wait a second then turn it back on when it warm and itll drive ok but feels like it has no power what so ever. it seems like is stumbles every couple hundred or so rpms. i can really feel it do this when im getting on the freeway and cruizing about 65 then trying to speed up wont go anywere in 5th liek i used to
over the past month or so that this has been gonig on ive replaced and/or clean mafs, tps adjusted to .489 closed, cap, rotor, plugs and wires, fuel filter z32, fixed the timing to stock, fuel pump, upgraded alternator to quest just because
so yeha really need help with this its my dd right now and its killing me with gas so if anyone has ideas that would be great or if i missed something you guys need to know just ask
-MilkMan
