SOHC rebuild question
driftiteasy0113
Car: SR PIGNOOOZZZE
hey guys im doing an oem rebuild on my kae and am planning on running like 7psi of boost. would you recommend using arp main, head, and rod studs and bolts on the oem rebuild?
singleslammer251
Car: 1989 Nissan 240sx SE Stock rebuilt KA24E mild N/A build
since you will already have it apart i would recommend do the arp head studs, the rod studs not so much. the stock internals can handle 7psi easily but play it safe and do it while you can. good luck
driftiteasy0113
Car: SR PIGNOOOZZZE
oh, ok cool. does anyone know what would be good to tune with for the sohc?
singleslammer251
well if you have 600 bucks jim wolf technology will reflash a auto ecu to your specs such has how much boost, size of injectors, etc. other than that maybe a Apexi super air flow controller (safc)
driftiteasy0113
Car: SR PIGNOOOZZZE
nice,thxdo you have a turbo kae?
Chris28
Car: 92 s13 KA-T
There aren't a lot of options as far as tuning goes for a KA-E. If you only want to run a small amount of boost I suggest going the FMU route. The KA-T section is a great resource, a lot of your turbo related questions can be answered there. Good luck
singleslammer251
haha i wish but no money to fund it right now lol. i have looked into it a TON tho so i know what to go for when i get some money.
driftiteasy0113
Car: SR PIGNOOOZZZE
what head gasket would you use?
dray3OOO
Car: 90 rb20 hatch HKS everythang
77 corolla stroke 2tg 40mm mikunis
please change your main and rod bearings especially if your have high milage and your gonna rebiuld for boost, studs and bearings and head gasket
driftiteasy0113
Car: SR PIGNOOOZZZE
well,ya im rebuilding the whole engine. with all new components except rods.so i will be getting new bearings fo sho.
singleslammer251
head gasket wise there is a guy with a website about a full turbo kae build and hes used a dohc cometic metal head gasket but cut off the front timing cover part cuz its different and used silicone on it.
