Brandon93240 »
https://forums.nicoclub.com/brandon93240-u58236.html
Mon Jun 18, 2007 10:53 am
I would stay between 9-9.5ish-1. You could boost with the higher compression but your not going to be able to safely make as much power. Just take a look at e36 bmws, they run considerably higher comp. ratios, they boost ok for 5-7 lbs but after that they'll melt pistons unless you have water/meth injection. 9.5-1 is higher than stock, so you'll have better driveability than you do now, and better out of boost response when you turbo it. If that engine really does have 89k I'd pull it apart, have the head redone(valve job, seals, resurface)buy some aftermarket pistons, have the rods checked and have new bearing and arp bolts installed and you should be ready to rock. You should be able to just have the cylinders honed with only 89k so standard bore pistons will work.
