SOHC problems, help
s13 iDRIFT
Car: White s13 Hatch
ok so im having this problem where i lose fluid from the radiator. no leaks, new water pump, radiator. i have one e fan, could that be the reason. i dont think its the head gasket, no oil in coolant or no coolant in oil. also it doesnt smoke! i personally think its cause one fan doesnt do enough cooling in 100 degrees so i think it just all evaporates l0l.
Gabes13
Car: rb20det s13
check the radiator cap.
s13 iDRIFT
ok, well i bought a clutch fan and put it on, filled my radiator up, check it when i got home from work and no fluid, and also check my oil, it was low for some reason? :confused: but ill be sure to change the cap.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Stop driving it, go to autozone / advanced and rent a "cooling system pressure tester" and a compression tester.
