Just wandering if anyone on here can help me out, would sohc pistons in a dohc make the compressrion ratio high enough to bend a stock rod? Does anyone have any information about this?? Thanks in advance for all your help!
No.The stock rotating assy on Nissans is one of the toughest, although if you take the time to build a motor, then you should polish the rods, or buy after market with out the oil hole.
The only problem I see is that I cant tell if they are the 11:1 or the 11.7:1 pistons... I kind of hope they are the 11 to 1 set, because I don't feel like going much higher than that in my DD.
