OniS14 »
https://forums.nicoclub.com/onis14-u37143.html
Thu Feb 09, 2006 4:00 am
i'm not feelin' that ricer kit at all..but...here's some info anyways..
-----------------------------------------------Single Cam to Twin Cam swap-----------------------------------------------
you will need:
twin cam motortwin cam motor harnesstwin cam ecutwin cam mafstwin cam intake pipetwin cam power steering lines (all)twin cam heater hosescustom a/c linestwin cam gauge cluster
you will need to completely remove all single cam power steering lines and install the twin cam lines; from reservoir to pump. install motor. the twin cam harness will need the brown gauge cluster plug removed and the white single cam cluster plug put on in its place. just match colors. those that dont match; discard. as far as a/c, the line ends can be changed by a competent line maker, or you can replace the condensor with a twin cam unit and hard line along firewall, changing only the fitting end going into the a/c evaperator via the fitting on the firewall
Credit: Taylor Durden [DURDAN PREFAB!]
