sohc lifters?
240man91
Car: 1991 nissan 240sx se hicas
Hey guys this might sound dumb but how do you adjust the sohc lifters?
neverlift
they are hydraulic and non adjustable..
this is ka general.
240man91
Yeah but see i put new head gasket in this sohc 240 i got ok and had valves replaced right well theres those screws on top where do i set them lol.
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
screws? are they on the rockers? Z24's had mechanical adjustment but idk how they would have found their way into a ka-e head??? put up a pic please. If has a z24 rocker assembly (which idk if it fits or why itd be there if it does) you adjust lash @ .015" by loosening the nut around the screw, threading the screw out then inserting a feeler gauge with wafers equaling .015" and tightening the screw till it makes contact with the wafers, then slowly/gently tighten the nut on the lash screw and remove the feeler gauge. in w/e case, you have to do this to every one if you didnt already know
240man91
Yes thats what it has a screw with a nut on the rockers. I will get a pic this is a 89 to. Idk if it matters. See i thought the same thing like you dont adjust them.
s13drifter88
yeah toss a pic up here as soon as you can
neverlift
please post a pic !!!!!!!!
you may have one of the only or maybe even the only sohc with adjustable valve lash(I looked into the conversion while I was sohc powered and it was not cheap or that easy from what I recall
s13drifter88
PICS PICS PICS!!!
240man91
Sorry guys someone came and bought the car off me for 1800 and yes it had the adjustable lifters in it i might see him tomarrow tho if so i will take the vc off and get pics. But on the same note i bought a 1990 sohc d21 and today on the way home the front main seal went out and it lost all of the oil well i shut it off soon as i herd the lifters tapping and filled it back up with oil but now it has a slight lifter tap. Do you guys think it has a bad lifter or one of the hydraulic rocker arms went out?.
240man91
O and that 240sx with the adjustable lifters was stock with them it was a all stock motor with its stock head.
neverlift
I have been around long enough to say this with confidence no STOCK 240sx came with adjustable lifters. I highly doubt they made just one(if they did it would have not gone into a production car)... Unless someone has some documentation to back it up that was a custom job :)
240man91
Haha i hear that man but the motor was all stock just couldnt see doing work like that and not putting a headder on or even a cold air. Any way what you guys think about my truck?
neverlift
hardbody luv man
but seriously get pics of those stock adjustable rockers..
s13drifter88
Z24 is only an 8 valve motor so the rocker assembly wouldnt swap over but I wonder if the rockers themselves would? That could explain it... maybe??? Hell Idk
240man91
I will get the pics for you guys saturday out of town working till friday.
s13drifter88
NEED... MOAR... PICS!!!
