S13FX »
https://forums.nicoclub.com/s13fx-u28329.html
Sun May 28, 2006 5:27 am
Dude SOHC all the way, mainly cause there is no check engine light so if you ever throw a stupid code it wont bother you, not that should drive arond with codes unless it's something we know will cause trouble.
Secondly the SOHC the 90 Model at least has lower comp it's like 9.1:1, so that is really decent for boost, Secondly It is really easy to work on, at least from my own personal experience, and third of all if you do decide to build the SOHC you can use higher compression pistons that were made for the DE and get much lower compression in the E, there is a post floating around here about that somewhere.
But engine for engine I'm very biased toward the SOHC even though they are both great engines. Oh and I think the SOHC is a little more rev happy, I took mine on the dyno stock and I made power all the way up to 6578rpm
