Sohc Ka T injector hell
BoostedSohcKA
Car: cars
well i still cant find a freaking set of 400cc injectros tha tfir my 90 sohc ka t HELP!!!!!!!!!!!!!!!!!
smug510
i have a sohc and i am running dsm 440cc injectors , i just had to shave a little bit off of the injector for the plug to fit
BoostedSohcKA
Car: cars
what ecu r u using ?
smug510
stock ecu w/ afc controller
Touchdown038
Car: Computers, cars, sports
Does it have to be 400cc or possibly a little larger?
smug510
its always better to go to big than to to small because you can always tune the big ones down but when you max out the small ones there is no more fuel
BoostedSohcKA
Car: cars
i have a jwt tunned ecu for 400 cc injectorsi
smug510
ya you should probably try to find some 400cc's i would look at rc injectors to see if the make some for a ka
smug510
here is a company that makes some 400's for nissans http://www.sportcarmotion.com/fuel.htm they are made from delphi they are 75 dollars each hope this helps
