Titan »
https://forums.nicoclub.com/titan-u5143.html
Sun Sep 04, 2005 10:46 am
Just this past Thursday I finally put the car back on the road, turbo setup complete.
I'm running a freshly rebuilt T3 from a Z31, currently at stock boost, 6 psi.
Nearly everything you see was made from scratch by myself in my garage. This includes the downpipe, complete exhaust, intercooler piping, etc. These peices are all 18 gauge mild mandrel bends, TIG welded by myself.
I'm running an S-AFC with 370cc injectors from a CA, resistors wired in of course. Tunning was done with my PLX Devices M300 wideband.
The car runs absolutely great, no bogging, stuttering, or hesitation of any kind. Infact it runs just like stock, other then the occasional backfire.14.7 in cruise/idle, 11.6-11.8 in boost.
This is my first attempt at turbocharging any motor, and I think it came out pretty decent.
Here is the car, pig nose chopped nicely for the front mount.
Here is the motor & turbo setup.
Here is the downpipe and exhaust, made completely from scratch. Both 3", no resonator. Sounds quiter then an NA with a 2.5" and resonator. Nice deep tone, absolutely no raspiness.
Here is the fancy cold pipe routing in order to avoid relocating the battery.
Here is the gauge pod and console. The gauge pod isn't pushed in entirely since I have to clean up some wiring behind it. Once fully in, it will be completely flush.
Now the neat thing is that the A/F Gauge is wired to show me my wideband signal.
Here is the wideband sensor, along with the converter that allows my A/F gauge to display the wideband signal.
I boxed in my rear lower control arms with 16 gauge sheet, much stiffer.
Some of you may remember the 18mm spacers I made a few months back. Here they are on the car. Open wheel racing anyone?
And finally, here is my TIG welder. Don't let the size fool you. It's a Miller Maxstar, 150A max, penetration good for 1/4" steel plate.
