SOHC KA build Questions (DeviousKA i need you)
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
i been looking around i couldnt get any info
sooooo i want to build a ka24et with high rev for my 240. to do so i would need to mate the KA head to a L or Z series block with a Fully Counter Weight crank. to mate anything to the ka head i need to bore the Cylinders to at least 89mm.
I want to get at least 10k rpm safely
the questions is a) what do i need for pistons and rods (would the ka rod and piston work)b) which block and crank should i getc) how would timing workd) anyother mods i need to do in order for this to work
thanks in advance for any info(i am posting this in the ka24et/ka24det too)
Rb240Coupe
Car: 1990 Nissan 240sx
10k
im not sure which block would be the best for your goal but goodluck with the build.
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
Hmmmmmm.
Well, I don't quite think you'll get 10K reliably without frequent teardowns. Keep in mind that no matter how ballanced you are, your piston speeds wont change. Period.
Get yourself a block from as late a model SOHC hardbody as you can find. They've got piston squirters. Or you could order some for a hardbody and have a machine shop drill and tap holes to mount them.
Forged pistons and rods.The crank is pretty reliableBearingsRingsYou'll need a brass oil pump/distributor drive gear to cope with sustained high RPM'sStiffer valve springs. Better, bigger valves. http://www.sivalves.com/onlinecatalog.html if you call them and ask for some custom valves they can help you for your situation.Solid adjustable rocker arms from hybridka.com I run em. They're great. They allow you to run any cam without needing to mill the towers and they'll hold up to the higher RPM's. My stock rockers kept collapsing at factory redline so I know yours will too. ~$300+shipping.Turbo camARP hardware. IE head studs, main and rod bolts/studs.I've seen people use a MLS head gasket for a KADE and cut off the timing cover section to fit on the KAE. Underdrive pulley for the water pump to prevent cavitation at high rpms. Turbo manifolds. jgstools.com makes a cast turbo manifold for the KAE and http://estore.websitepros.com/...t.bok (O & J performance) makes an intake manifold for the KAE.Injectorsfuel pumpAdjustable FPR. an SR20DET FPR will fit with little modificationsObviously a way to control and tune the motornew ignition system. IE MSD/Mallory coil, amplifier, and wiresAll the appropriate guageswideband O2propper exhaustFMICPort, pollish headBrass valve guides
I know there's more.......
