SOHC KA build for high rev Question
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
i been looking around i couldnt get any info
sooooo i want to build a ka24et with high rev for my 240. to do so i would need to mate the KA head to a L or Z series block with a Fully Counter Weight crank. to mate anything to the ka head i need to bore the Cylinders to at least 89mm.
I want to get at least 10k rpm safely
the questions is a) what do i need for pistons and rods (would the ka rod and piston work)b) which block and crank should i getc) how would timing workd) anyother mods i need to do in order for this to work
thanks in advance for any info(i am posting this in the ka24e/ka24de too)
240sxka-t
Car: 94 sentra ga16 coupe
if you want high rev's, why not just put an sr20 in? low end torque is what the ka is all about. not so much on the top end.
AZ89two4Tsx
Holy bejesus, 10K?
What the hell for? I can't see any KA being effective at that ridiculous RPM.
undesiredshoe
Car: 240sx
Please sir, just give up on that idea. Its hard enough on an already high revving civic.
