locoluna825 »
https://forums.nicoclub.com/locoluna825-u93365.html
Sun Mar 07, 2010 9:14 pm
Oh I see. well maybe its a mistake or something, those are ev1 injector harnesses though so they will fit an sohc injector but as to why theres 6 plugs it beats me.
I do know that on a sohc injector section of the wiring harness there is technicaly six plugs. 4 for the injectors. The other two wich are pretty close to the rest of the injector connections. Go to the idle air control valve and idle air injection valve.
Maybe thats a reason it says its for the 300zx too, its universal. Its just two wires with connectors. all you do is attach them to the rcorresponding wire for your application.
So 4 for the injectors and 2 for the idle air system on a 240sx SOHC, thats 3 connectors per harness, from what I can see. Then 3 for each injector on the v6 300zx. hope i helped a little and didnt make more confusion
