SOHC growls when accelerating
el5y
Car: 93 240sx
Hey, my brother's 240 makes a hell of a lotta noise when he's trying to accelerate, it sounds like the fan is working in overdrive or something, but then again it could be the belts, but we're not exactly sure, any ideas? thanks
Eric
WAbernethy
If it sounds like the fan, whhhhhhhrrrrrrr, like a damn truck. It's probably the fan clutch. Lose the mechanical fan alltogether, you can get an electric one and thermostat for less than 100 bucks.
randybunctious
Car: racing yo mama
a used a/c condensor fan will work= cheap as hell, a lot cheaper than buying a fan clutch., i have one if you need one though
knightrider
Car: black 90 240 coupe
lose the clutch fan, goto the junkyard, and buy the dual fans from an altima. wire em up either on a switch or always on with ignition(recommended)
el5y
Car: 93 240sx
Heh, sounds good, my brother wants to know if he has to replace it or if he can just live with the noise.....thanks guys
Eric
NISTECH
you might not want to live with it as this could be the end result.http://www.nissaninfiniticlub....55039
