Right now I am in the middle of a build. SOHC Using, JE Forged(Nismo) pop ups (yeah I'am an old school person) Carrillo rods (also Nismo) and Total Seal new trick rings I've had good luck with them, some folks don't like them.) Looking at around 12 1/2 to 13 to 1 compression on race gas. Most likely the engine won't be fired until this fall, as the race season has started and I don't want the down time to get the bugs out. Many logistic probs with flywheels, crank, etc. I want it right as I only want to spend money very carefully and I want the engine to live. Will be running a modified stock fuel injection set up, with a modified ECU and all. Many new things that I am dong on this, on which the old engine does not have. (Datsun L-16 series) That's all I am going to talk about now.
Timing wise, since this will be a race engine I don't have to worry about low end rpm's, the engine is being built to operate between 3,200 and 7,000 rpm's. This is going into a midget asphalt/dirt race car.Check us out at:
http://www.pcmidgets.com My car is the #66 car. MIKE
