BoyWonder »
https://forums.nicoclub.com/boywonder-u12909.html
Mon Jun 28, 2004 5:45 pm
The only thing that could make a difference is the flywheel that you use, but I've seen both a stock SOHC and a stock DOHC flywheel and they look very similar.. I however have never done a side-by-side comparison. My point is if you're using a flywheel from a DOHC, it'd be a safer bet to get a DOHC clutch. Likewise for the SOHC flywheel. Someone may be able to chime in with personal expirence or a side-by-side of them both but I'm pretty sure they are the same all around. If you look on Ebay, some people sell 89-98 compatible clutches, some 89-94 clutches, and some that only work on 89-90 and 95-98. Go figure.
