SOHC DOHC swap final wiring questions... searched.
alpalwal
I'm trying to finish up my sohc dohc swap and the cluster wiring is giving me some problems. There is a white plug and a brown plug on the main harness and then the white plug on the cluster harness..
From my understanding the brown plug goes to the white cluster plug...
Where does the white plug on the main harness go?
alpalwal
up
Burnsey
Car: '92 Infiniti Q45 ... 89' Nissan 240sx
send me an email with a pic if you could and I'll email you pics/explanation later today (around 5-7) when i get off work ... i have my car still stripped and could prolly take pics/explain it b/c i just finished that swap.
sileightysomeday
if you get the DOHC harness isn't just plug and play? im in the middle of a SOHC to DOHC swap also, and i just took the DOHC harness and plug it into the two plugs for the dash. there are 3 clips from the back of the cluster that go into two on main harness. one is white and the black one is a little further in the dash, i took off my entire dash because it's easier to wire.
