I have an 89 hatch that used to have a sohc. After my tming chain guides broke, I decided to delete the emissions stuff using the thread I found at this forum.
zerothread/274166 I can do this since I live in Rio Rancho, NM and we don't do emissions yet. (Jan 2010 maybe) Unfortunately, it didn't work. I thought I messed up the timing, with other stuff that happened, I eventually picked up another sohc for $50 and was told it worked, but it didn't. Both of my blocks were shot as I eventually found out.
Then I got an offer for a working dohc and was allowed to install it before I bought it. The motor was very dirty with oil and dirt. I purchased the motor and the car it came out of for $500 because the gasket needed to be changed. I removed the air compressor and installed the motor. I referred to several threads about the swap. The first was about swapping the ecu. I did the body harness mods as the one in these threads:
zerothread/16244http://forums.nicoclub. ... ead/283484
I also did the tach swap with the help of these threads. I had pictures of most of this stuff but now I can't find them. Did I mention I'm a pothead?
Anyways... The car worked!!!
-It is all bone stock. The following are things I have done to it.Vacuum line removal-Removed that retarted line that comes out of the exhaust and back into the intake-Removed all A/C components and brackets-I couldn't delete the PS like on the SOHC, so I idled the PS pump-Gutted the rear behind the seats, so I have a 2 seater
Needs:-5-speed swap-a little brake work-lowered-headers, intake, exhaust(the basic stuff)
I don't believe I have a governer and I can easily fly in the highway. I know I reach 60mph within a few seconds and 60-100 even faster. No doubt I don't need an SR20DET to be fast.
Heres the carHere's the motor
The exhaust thing I deleted
The idled PS pump
just added an overfill
I would like to thank NicoClub for this forum, My neighbor Steve Roscoe and his son Matt who devoted themselves to help me, and my uncle for his extensive knowledge of machanics and his diagnostics nose.
Modified by GEMINEMESIS at 1:08 PM 10/7/2009
Modified by GEMINEMESIS at 9:02 PM 10/7/2009
