SOHC chain guide factory upgrade? what?
Nameless EJ6
Car: What the **** do you think.
I've got an 89 240 and I'm doing some work on the motor, replacing the timing chain guides..
Went to the dealer and apparently (yes I've searched a bit) there are two different slack guides. The parts guy informed me if I have a 240 produced before 3/1989 then it uses this one, if after 3/89 that one..
Does it really matter which one? The tension guide was an upgraded part, so I got that.. but the slack guide... I don't really know which one I need so I got the newer one which looked similar to the one I took off the motor.
I can't imagine why it wouldn't work... if anyone can help me out I'd really appreciate it! Thanks
180fan
Car: 89 fastback
they are different part numbers, but I'm not exactly sure what's different. One thing I'm pretty sure of though, is a service bulletin that went out for the early 89 cars. So I'm assuming there was some revision done for the later model sohcs to correct that.
ricebike
2002 Quest
2005 Altima
it was more of a national recall to have the timing parts replaced d/t the old plastic ones weren't cutting it... now had metal-backed plastic guides as the revisions.
this is a 1st to have 2 diff part #s for that particular set on the KA24E... Y don't u just tell the parts guy to pull both of them off the shelf & show them to u. you can also find your manufacturer code on the door jamb plate... mine's 9/88
that way, we can all learn of the differences... aftermarket didn't have such thing & I'm currently ok w/ the set i got...
skylinekin
Car: 1990 Nissan 240SX Hatchback
adding to this question, can you replace guides without removing the front cover? im missing the tension side guide.
180fan
Car: 89 fastback
nope you can't put in new guides without pulling the front cover.
Nameless EJ6
I probably confused some of you guys.
The tension guide (left side) is the one with two part numbers.
The straight guide (right side) apparently was changed as well.. but you can't order the older one. (from what I was told).
Anyways, I ended up getting the right parts. If anyone has questions feel free to post and I can get pics if needed.
skylinekin
this sucks, the parts are cheap but its going to take a good weekend to change the guides.
