deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Wed Apr 07, 2004 8:13 am
No you dont have to do any line-honing. The only operation necessary with the cam towers, with a colt cams regrind, is milling down the tops. This is to lower the entire rocker assembly, and make up for the smaller base circle of the cam. I dont think this is necessary with the colt/pdm stage 1 cam tho. When i was running the c404h, i think it required .025" or so removed from the top of the towers. Exact specs on on pdm site, and also included when you get your cam. This has to be done by machine shop, very simple and cheap operation.
Maybe the person meant that you cannot mix up and reinstall your cam towers in the wrong location, im sure you know to keep them in order and not install them backwards. They are numbered and arrows are there to show you the front, its a nissan remember.
